oops what have I done?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Over heated front engine/transmission mount which is made from rubber. The old tranny can get pretty hot.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
I took the car out again today and the clutch is definatly ok,The vibration is still there but only on hard acceleration whilst taking a bend.I'm starting to think maybe this is the very low suspension on maybe not so good shocks,is it possible that under hard acceleration with a crappy suspension set up that the car is maybe bouncing on the shocks due to lack of travel??I am going to take the car to autostrasse next week end for a check up.
I will be a bit more carefull when taking off in the future.I'm not into wheel spinning everywhere but this goon in a blacked out Golf GTI with blond bimbo started the abuse and yeh you know the rest and yeh when my clutch finally hooked up I blew him away.How hard is it not to take the bait with the max power spotty brigade
Paul
C2 cab
Paul
C2 cab
Good luck on the diagnosis. Hopefully the repairs won't break the bank.
A burning clutch also smells very much like burning rubber.
I won't tell you how I know...
That's why I had Jeff help me install a new clutch in my car.
How hard is it not to take the bait with the max power spotty brigade...
Dove
I'm sure you know this, but you are in a no win situation when you succumb to the rice brigade. Let them have the monopoly on neon lights and dark tint - whatever floats their boat. Just beware that 964's are great cars but aren't the quickest 0-60 beasts around.
Originally posted by Phil Raby
Paul, does your clutch still smell?
Cheers
Cheers
Paul
C2 cab
I did drop the clutch once on my C4 and the smell was horrible, less than 1000Km later suddenly the gear were not engaging and later the car wouldn´t move, the result new clutch.
I´ll never do that again. The only positive thing the DMF was checked and it was fine so no need to replace.
ALEX
ALEX
