964 Forum 1989-1994
Lock nuts ?
Old Feb 14, 2020 | 09:57 AM
r-mm's Avatar
r-mm
Hi all
Resurrecting an old thread as I look for the M6 locknuts which are used many many places. I see these offered at $.50 each for instance: https://www.fcpeuro.com/products/por...er-99908409402
However reading above, if in fact these all metal locknuts can be reused, I wonder what the downside to doing just that is? Many are on top of the motor where there is less corrosion and, if we are honest, usually a decent coating of oil as protection.
The closest thing I could find at McMaster is these distorted thread locknuts which are specifically said not to be reusable. https://www.mcmaster.com/93795a220
Old Feb 14, 2020 | 10:25 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
THESE are regular zinc and not yellow but only $0.08/each from Metric MCC and located in New York, so they will arrive the next day.
Old Feb 14, 2020 | 12:00 PM
r-mm's Avatar
r-mm
I wrote to see if they will give me an account. Thanks.
Old Feb 14, 2020 | 01:00 PM
Goughary's Avatar
Goughary
Porsche has all of their locknuts listed as "not reusable" - which is not really the case.
Sometimes it's the correct thing to do to replace. But in most cases - reuse is fine and if you are concerned, a little thread locker is good enough.
Old Feb 14, 2020 | 01:27 PM
DobermanDad's Avatar
DobermanDad
Always like McMaster CARR for hardware myself.
Old Feb 14, 2020 | 01:31 PM
r-mm's Avatar
r-mm
As do I but tell me if you see a better all metal locknut than what I linked to.
Old Feb 14, 2020 | 01:34 PM
r-mm's Avatar
r-mm
This was my instinct. So much goes into a nut's specification that if its in reasonable shape I try to reuse it.
