air/oil separator question
I'm removing the intake this weekend to replace all the vac hoses. Is there an o ring or seal on the air/ oil separator. The 'cap' where the breather hose elbow connects to looks like it can come off. If so, how is it removed so I dont break it?
The top doesn't come off w/out destroying it. You have to remove the turbo, downpipe, and heat shield to have enough room to take it off the block to replace the o-rings. It has two o-rings of different sizes.
Originally posted by David Floyd
I think there is an o-ring, I tried to disassemble mine but it seemed to want to break so I just ran a bead of black silicone around the seam.
