Lowered the price on my 951
Just got the car back from Chris White. it drives amazing. Power comes on even quicker and smoother. Does need the balance shaft seals, upper is leaking. My ring gear is missing 2 teeth(this recently happened) still starts but you can hear that 2 teeth are missing only when starting you notice.
https://hudsonvalley.craigslist.org/cto/6177112612.html
Mod list
Engine-
88mm crank
7:5:1 JE pistons
Oil pan baffle
104mm bore with darton sleeves
Pauter rods
49mm intake valves
Race springs and retainers (bf racing)
Race cam (bf racing
Upgraded intake manifold (SFR)
Front mount intercooler (SFR)
Custom fuel rail
1000cc injectors (Injector dynamics)
3 bar FPR
custom fuel rail
Larts fuel lines
Tial 44mm WG
6262 turbo charger
Lindsey 3 inch turbo back
4 inch bf muffler
Forge diverter valve
Electromotive Tec s engine management
90 percent of the vacuum lines are duel walled
Profec b spec 2 EBC
Ported and polished head
MLS HG
Vented catch can
Suspension/ brakes
All new Zimmerman drilled rotors
All new hawk hps pads (front) possible stop tech in the rear
E brake shoes have under 3,000miles
Koni yellows
Rennlist bay solid ball joint kit (new)
Elephant racing sport caster blocks and control arm bushing (front,brand new)
Brand new brake master cylinder
Transmission
LSD
Spec stage 2+ hybrid clutch (under 1K miles$
Aluminum pressure plate (under 1K miles)
Aluminum fly wheel (under 1K miles)
Also have custom axels and custom joints brand new in the box with trans brace brand new
Tires
Have 90 percent left front and rear
275/35/18 225/30/18 Bridgestone potenzas on Italian made reps Carrara light weights. Perfect condition
Exterior
3m matte metallic blue wrap (3 years old)
It's in good shape some chips one spot on rear bumper ( have to check the rest )
Original color is alpine white. If you remove wrap I would recommend a paint job
BF racing fiberglass front bumper
Vented header panel
924 CGT hood scoop
Interior
Burgundy color
Inside roof and panels are black vinyl
Black recaro seats removed 5 point harness
Pioneer radio 8200bt little old now
Front door speakers are Hybrid mirus
Memphis 4 channel amp with 10 inch Memphis sub
Shelby remote start works great as a turbo timber
Innovative air fuel gauge LC-2
Boost gauge
Mod list
Engine-
88mm crank
7:5:1 JE pistons
Oil pan baffle
Pauter rods
49mm intake valves
Race cam (bf racing
Custom fuel rail
3 bar FPR
custom fuel rail
Larts fuel lines
Tial 44mm WG
6262 turbo charger
4 inch bf muffler
Profec b spec 2 EBC
MLS HG
Vented catch can
Suspension/ brakes
Koni yellows
Transmission
LSD
Tires
Exterior
Vented header panel
924 CGT hood scoop
Interior
Burgundy color
Boost gauge
Price is now down to 12k OBO. Some one give this car a good home. LOTS of time into it and way to much money. Looking to get into somthing more modern!
951s and other German cars have done well on BaT - I would look at posting it there and putting in a reasonable reserve. Just a thought, certainly something I would consider for mine when the time comes.
Basic Sponsor
Lol BaT, your car will come to me it's his destiny
Basic Sponsor
Originally Posted by KVDR
Ugh, I know the struggle. I had a heavily modified (but tasteful) '87 Mustang that wouldn't sell. I ended up parting it out and getting back about half my 'investment'.
