3 Liter Turbo for Dummies?
Would it work to build a 3 liter turbo out of a 968 motor by:
1. Replacing the pistons with the new Mahle 3 liter turbo pistons
2. Using a 2.7 N/A head, modified to port match the intake manifold, and to modify the water passage to match the 3 liter block (hi-tech exhaust valves needed?)
If so, would this set up drop in to a 951 with stock exhaust and turbo plumbing without hassles?
What flywheel/clutch/starter is needed to install with a stock 951 power train?
Does the 86 style timing belt tensioner/waterpump set up work with this combination, or is something else needed?
Does the stock turbo cam work with the 2.7 head?
Do all 951 accessories bolt to the 3 liter block (alternator, power steering, a/c, motor mounts, etc.)
- 951 exhaust valves can be used, also the valve springs must be changed.
- The 3.0L block has the late style (post 86) tensioners.
- 951 Waterpump may not work with a 3.0L block.
- All other 951 parts should work.
- Balance shaft cover needs to be modified for turbo oil feed line.
- 951 Engine mount (left one for turbo), and oil pan to be used.
Selecting the proper turbo and the tuning where things get to be interesting...
I understand a rod change may be appropriate too - stock length, but forged. It's also an opportunity to drop some recip. weight by using say a Pauter rod. The foged 951 rod should be just fine and groovy too, but I'd work them over (shot peen, resize/rebush, balance both ends) and use aftermarket bolts/nuts - ARP's are nice. At that point, you might be better off just buying a Pauter rod set for the money. On my rebuild that I'm ready to put in my '87 car, I used '83 944 rods (forged) and was able to take 10 grams off each rod by smoothing the sharp edges and cutting down the balance pads - kinda not worth the effort, really, but I had the time. Design wise, I think the '83 forged rod is superior to the turbo rod, but that's just from observing the two side by side. Their weights were virtually identical between the 2 designs. The turbo rod looked like it had more opportunity to shave weight and had much sharper shape transitions. Here is a pic of the rods next to each other, the bottom is the 951 rod.
Also as for the dogma that only '86 turbo rods were forged, I've yet to see any turbo engine that upon tear-down had anything but the forged rod in it (?) . . . personally witnessed '86, and '87 engines and seen pics of stock 88 and 89 disassemblies, all had the telltale "square" rods.
I have read on the board that some M.Y. 968 rods were cast and later M.Y. rods were forged . . . I would NOT trust a cast rod in any HP engine. Based on a previous board discussion, I'd prob. not reuse ANY 968 rod. Here is a pic from that thread with the 968 rod (bent) and a turbo rod in the middle.
It is my understanding that the forging method used for the early 944s is similar to the 87&up turbo rods, ie sintered. The 86 turbos had fully forged rods, making them the strongest of the bunch. BTW, I've seen an 86 turbo that broke a piston, and besides that the bottom end was fine.
Ahmet
Ahmet
Re: 3 Liter Turbo for Dummies?
Originally posted by Tom M'Guinn
[B]Would it work to build a 3 liter turbo out of a 968 motor by:
Yes I have one in my car that has been reliable for the last 7 yrs.
In my case, the 968 housing was modified to clear the wastegate and a custom billet flywheel was used with the 968 torque tube but this is not required.
Trust me, to tune it is not rocket science. I am currently running a APE MAF setup with a K27/8 and it works very well. You can either run stock injectors upto 320rwhp (maxing them out) or go to bigger injectors and get a piggy back of some kind to fine tune the bigger injectors.
I have 2 sets of chips for this setup. Let me know if I can be of any help. I just pulled on a 3.6 turbo that was running 1 bar and custom exhaust. I am running similar boost and was pulling on him. I thought that was pretty impressive for a car that is used as a daily driver sometimes.
raj, i changed my mind about going the 8V route. Since i have a good source for japanese engine management system here in the far east, 16V head seems to be the better option.
According to Powerhaus, their 16V turbo made 100ftlbs more torque.....
Recently, I was talking to a friend (an Electronics Engineer - DSP expert). He did an atopsy on my Power Perfect(951) and the Authronic EMS, then laughed his head off when he found out about the $$$. HE claims that we could easily make/or copy one for a fraction of the cost.
hmmm, maybe...
hmmm, maybe...
Songzzz, that's definitely true, especially with manufacturing in the Far East - I've thought about similar things, not only with electronics but with production stuff like replacement lower control arms, etc - setup/tooling/mold fees would be so easy to recoup on those to bring out a far cheaper product
Sam
Sam
Sam, Right. I custom made my 951 intercooler in Taiwan for only about USD 200!!!
I have the connections with several the good factories over here that can easily come out with those stuff you mentioned. Before going into such OEM business, the crucial factor would be the "quantity".
If you are seriously looking into doing it, send me a PM, we can work out something.
Anyone knows where Motech manufacture their stuff?
Songzzz, Motec is an Aussie company.
Ask David, how does the torque peak compare between a 16 valve and an 8 valve head. If you want an all out racer that is more high strung, 16 valves is the way to go. It will require additional custom exhaust and intake. Also, you will need to figure out which head to use.
If you want a fast car that is a pleasure to drive around town and has gobs of low end torque, 8 valve is the route. Like I said earlier in another post, I was able to pull on a 3.6 turbo
