What's causing tach to jump around?
I tested the reference and speed sensors. Both speed sensors tested perfect per Clark's Garage test procedure. Next I pull out the gauge and check grounds and connections. However since this gauge works off a square wave, has anyone seen this before?
The tach is actually driven by the ignition coil pulses in our cars, so if your car is running fine, the tach is probably the issue rather than the signal it's getting.
The tach signal is generated by the DME and then goes to the tach. Completly different wire than the trigger wire that runs to the coil. Does the needle always "bounce" at the same spot?
True, though the tach does use the same dme ignition pulse that is sent to the KLR for timing adjustments, then returned to the DME to create the coil-level pulse. So if the tach signal were bad (at the DME), so would the signal to the coil... I'd be inclined to check all connections including the edge card behind the instruments, the little football connectors on the back of the cluster, and the connector in the footwell that carries the signal to the tach. If that's all good, I'l blow air in the tach, gently, in case there's dust or debris inside, and then maybe try a tiny drop of sewing machine oil on the shaft...
Thanks for reminding me ECU doc. I ordered a used gauge from Lart. Yes my tach worked but something is wrong with the counter springs and it falls too sharply and then bounces. The one from Lart works like the one in Tom's video shows - manually moving the tach.
So for those that have a bouncing tach unrelated to the reference sensors; it's the internal windings. There are a lot of threads about tach bouncing related to starting issues/ref & speed sensors. Hopefully this thread will help someone down the road outside of the normal tach bouncing starting issue.
thanks Tom and Lart!
