951 clutch replacement
Lart from everything I have read on here it appears that the cup disk is recommended rather than the 930. I have read....no personal experience....that the 930 disk is slightly too thick.
Not sure if you know or have used the 930 disk without issue?
Cup disk appears to also be a pretty good value to purchase new.
Basic Sponsor
edit: Well I went back and did a search on here and can't find any recent 2012 and newer issues with the 930.....wondering if past issues were just a small batch or someone not installing the clutch properly.
but as it appears from Lart the 930 disk will work
Quote from Paragon https://www.paragon-products.com/Clu...116.014.02.htm
"Also as an upgrade to all 944 Turbo. Slightly larger disc area, better disc material and
slightly thicker. Fits with no modification."
Good info Lart
I am curious if it is specific clutch pressure plates that people had with the 930 disks posted on here. Those posts go back a while.
What pressure plates have you used with the 930 disk?
The RAGE2 car has a Kep 1 but I think it had the cup disk with 4 springs. I will have to go look in my parts bins later.
Good info Lart
