Quick question about Link 1&2 ???
Old 11-11-2003, 03:08 PM
*eurospeed951*
*eurospeed951*'s Avatar
Default Quick question about Link 1&2 ???
I see that all of the tunner shops are includeing wireing harnesses in their kits. My question is, if all the stock sensors are being used in their stock locations can the Link be used without this harnness? I agree it is a good idea to replace the old wireing. I just was woundering.
Old 11-11-2003, 03:12 PM
superjet.1
superjet.1's Avatar
Default harness
You can use the harness that comes with the link 1or2 but its a ton of work id highly suggest using the link custom harness its plug and play. I know its costly but those dam stock bosch connectors are pricey but the quality is very high.
Old 11-11-2003, 03:26 PM
*eurospeed951*
ok, so in the end you have to use some sort of harrnes. You can't just plug and play correct? Thanks
Old 11-11-2003, 03:28 PM
superjet.1
superjet.1's Avatar
no you need a harness it dosent plug into your stock connectors under the dash.
Old 11-11-2003, 03:29 PM
B951S
B951S's Avatar
Trust me, buy the harness, you wont regret it. DOing it with the link breakout loom only is possible but is a lot of hassel
Quick Reply: Quick question about Link 1&2 ???
