wiring O2 sensor
wiring O2 sensor
Hi,
I have an Euro car without O2 sensor. Last week I installed the LR MAF2 system. I have purchased a 4 wire O2 sensor. 2 white wires, 1 black and 1 grey wire. Now I'm connecting the wiring to the injector A/F meter. I connected the black wire from the sensor to the green wire of the A/F meter.
I like to know where to connect one white and the grey wire at?
I have been told that I can just leave one white wire. I that correct?
Thanks for your reply,
Arjan
Arjan
The white wires are for the heater, connect one to a switched 12volt source that powers with the key in the run position, connect the other one to a ground.
Are you sure the black wire is not the ground? and perhaps the grey wire is the sensor output?
Todd, O2 sensor is mainly used to keep the A/F ratio close to stoichiometric, in order to minimize the emissions (and also to keep the cat in shape, I assume they go bad real fast with too rich mixture). My euro spec 951 came without an O2 sensor, because there was no need for one... (I did add one just few weeks ago to hook up my A/F gauge, but it's not connected to the motronic box in any way)
If your car runs too rich, the O2 sensor is probably toasted. There's probably some trick way of testing a sensor, maybe a google search would come up with something? Also if you have an A/F gauge, the display should dither around 14.7:1 on idle and while cruising, switching between rich and lean rapidly ... if it doesn't the O2 sensor isn't working (or is disconnected).
I honestly don't know... I would assume all cars that have a catalytic converter run O2 sensors, and I also thought all US 951s had cats. Anybody know for sure??
Drive-by provocation guy
I understand if cat is out or no need for emmisions tests, you don;t need it, but how does a/f/ get registered?
I mean if your not running a MAF or MAP how does the DME regulate a/f ratios if no o2 sensor??
All US models came with O2 sensors. All ROW cars came without them. The ROW turbos had the bungs welded on the exhaust to accept the O2 sensor but they were plugged. The ROW other cars were not equipped with the O2 bungs.
There may be some deviations to this due to a number of reasons, but that is what I have found to be true.
The 951's and other fuel injected cars what came without O2 sensors just read the airflow signal (from AFM, MAP, MAF,...) and look up the necessary amount of fuel from the chips (or something like that, depends on the implementation naturally). The only difference is that if there's an O2 sensor, the computer can make small adjustments to the mixture... FR Wilk does a good job in describing how it works, see http://www.frwilk.com/944dme/ -> "Lambda inside"
Travis, guess what - I'm 99% sure my car doesn't have the O2 bung! I double-checked the location from PET, but just couldn't find it anywhere on the car... weird huh! Not sure if it could be because my car just happens to be one of the very first ones, chassis number 79 IIRC ... also some euro cars did have O2 sensors, I'm not sure if cat was an option all the way or if they made it standard in some model year.
