Lindsey Racing Super 53
Im contemplating another turbo upgrade, Im considering a Lindsey super 53, there are some old posts on this topic that have been very helpful providing feedback, is anyone currently running one? Seems like a good fit for moderate power and decent spool.
Quit Smokin'
There's a rennlist member that's going to try to get a group buy on a custom billet k26 based turbo. he's going to be posting in a day or so. I have his prototype on my autocross car that is very much in development still. with a stock waste gate, cycling valve / LBE, AFM, it out spools the original K26/6, and has no trouble running out the injectors @ 273 wheel hp, 320 tq shutting it down just before 5000 rpm..... on a mustang dyno that's pretty cruel.
I'm running a Super 53 twin ball bearing turbo with "P" trim in my car. I'm very happy with it, spools quickly and makes good power (butt dyno only). I swapped it for a K27/6 that was in the car previously.
It's a bolt up to the stock mount, the ball bearing center cartridge meant I had to fabricate the piping for the turbo coolant lines. I don't think that would be an issue with a plain bearing turbo.
I have the 53 in my 87 turbo. Have had it 3 summers, several track days and several 4 to 8 hour Sunday drives. Zero issues. It spools a bit later but then "bam". Lots of fun and on a larger track(Mosport is my home track) is where it seems to be the happiest. Cheers.
I've had mine in for since the summer of 2014 with no issues. I used an oil restrictor and the oil line that Lindsey sells, no smoking issues.
What's deceptive is that while this turbo might make full boost later in the rev range, it makes more power at lower boost levels than the K27/6. More efficient blade design means lower intake temps (I think) as well as a less restriction from the turbine side...especially when I realized I had a pretty good leak at the head/exhaust manifold, oops.
I will say that the ball bearings make a different noise when spooling than a plain bearing, a bit of a whine. I'll admit it freaked me out the first few times, fortunately Rogue had warned me. I went with this setup based on his recommendation btw.
