Ealokens Porshe 951
01-08-2017, 11:20 PM
Quote:
Originally Posted by
ealoken
So there they are, 8,5x17" And 10x17"
Fitted with Toyo R888 235/45-17 And 255/40-17
Those looks really good! Especially with the meaty r888s.
01-24-2017, 05:33 PM
01-26-2017, 06:13 PM
01-30-2017, 10:17 AM
Flow numbers before head job.
232CFM 10 mm lift innlet
Og 152CFM 10mm lift exhaust
02-03-2017, 03:08 AM
More parts.
02-03-2017, 04:44 AM
AddictRennlist Member
Nice work, what's the cleaning process you used on the head? Soda blasting?
02-03-2017, 04:46 AM
Voith
It was glass blasted, didnt do the upper cam cover since the camshaft still was inn.
02-08-2017, 10:05 AM
The rear Seat delete is done
02-12-2017, 11:32 AM
02-13-2017, 12:48 PM
where did you get the carpet for your rear seat delete project?
02-13-2017, 01:08 PM
I bought it from a high-fi shop, they use it on subwoofers and so, neede some cutting. then i used Motip Glue spray and some time, it`s not perfect. The carpet was about 20$
02-13-2017, 01:12 PM
02-13-2017, 01:32 PM
Ah. Simple and easy to find. I could not tell from the pics but it looked like stock carpet material.
02-13-2017, 01:45 PM
I was lucky on the colour, And IT has some stretch, easy to work with
02-18-2017, 02:34 PM
So one of the intake valves had a danmage, Got that replaced, he has some job left before i Can mount it back in.
