Ealokens Porshe 951
#301
I'll go with chargecooler in intake plenum setup and direct turbo -> TB -> chargecooler air route. Should be fun. Shoehorning it all on top of engine will be challenging.
#302
It's still in parts. Will probably have to reduce runner length to get it to clear brake booster. If not I'm considering using 964T servo powered booster.
#311
If you need, I can send you my PDF copies of the service manuals.
The engine is looking great BTW, I'm keen to see what kind of performance you get out of it.
#315
Which manual are you using? The proper Porsche service manual does tell you were to use the 574. It doesn't need to cover the whole girdle, just the oil channels and edges of the RMS area. The 574 also goes on the balance shaft covers.
the loctite was only used Where the girdle meets the block.
yes please, ealoken(at)Gmail.com
i hope to se power from 3500-7000 rpm 500whp/wtq.
