My plan was out the top, but I can change plans and go out the bottom. I'll drop the tranny and pull back the torque tube first, the last engine I pulled out the bottom was annoying because of clearance from the shaft.
Hoping the torque tube to bellhousing bolts are accessible enough with the crossover. Swearing and swivels will be used, I'm sure.
I cant remember if you can access the top two BH bolts easily with the Xover attached...been a while since I've messed with a 951 sadly
Yes you can.
Though, I would prefer to drop my radiator instead of dropping the box and moving the tt back.
I had loads of room after taking out the radiator and the bottom radiator support.
I haven't taken the engine out the top before...but after seeing how easy it is to drop it out the bottom, I'd recommend you just do that. After disconnecting everything...sliding the engine off the tt and lowering it down took me only a couple of minutes.
Cutt off torch... had the same thing happen to me and spent a week trying to get it out just to have a friend make fun of me and torch it off in 5 secs. He did it with the engine still in and I believe he cut off the tacked nut as well but sucker was off.
Closure today. Finally had a few hours to work on things, and I took a sawzall to the crossover (just the tacked nut). I had to remove the brake MC to get in there, but worth it easily. Crossover is off, now just on to the other cramped work areas on this car.
Now smash nut with large hammer and then attack it with a cutting torch.....you will feel very good afterwards
Thanks guys, I actually AM keeping it for something vengeful. I also have the bolt that fell into the bellhousing on my NA about a year ago, requiring me to pull the trans/torque tube/BH/flywheel.... I'll probably bring them to the range and take pot shots at them It felt so good to take the sawzall to it.
