Oil Cooler Line Replacement
Folks -- Any easy way to get at the oil cooler line coupling directly behind the oil filter? Mine's developed a leak and I need to replace it.
I have got the same leak. I have not replaced the line yet, but I got a wrench on the fittings by removing the filter and the distributor cap. This is all from the top. There is a fitting on the line as well as an adapter that screws into the block. You need 27 and 32 mm wrenches (Sears has em). You can move them about 5 degrees at a time. Let me know how it goes because I am planning on it at the next oil change.
