951S / Cayman S Tuning Project
#31
LOL right you are.... I have some posts to edit now...
#33
I have a picture in one of the posts with the elbow on. This is the only way to mount it. Note that you'll want to loosen the exhaust downstream in order to get the adapters to mate up where they should. Probably you will need to remove the wastegate bracket from the torque tube as well. It might be a day or two before I get under the car again, but I will try and get a picture for you.
