Testing TiAL F38 WG in single port mode. Smoke and oil everywhere.
Old 10-05-2016, 09:13 PM
  #31
lart951
Basic Sponsor
lart951's Avatar
With detonation lots of things are possible
Old 10-05-2016, 09:23 PM
  #32
darenchu
darenchu's Avatar
Just to clarify, what does the manual boost controller do to regulate boost when dialed to 10psi - lower? Anything at all? Would that not be the same as running no boost controller? I was under the assumption that the purpose of the boost controller was to
a. Replace the cycling valve (why?)
b. Increase boost beyond spring pressure (danger?)
Would it have been a A:F ratio problem causing it to detonate or something (is this possible in this scenario)?
Last edited by darenchu; 10-05-2016 at 09:25 PM. Reason: edit: okay Lart answered my question if detonation was a possibility lol
Old 10-05-2016, 10:25 PM
  #33
rlm328
rlm328's Avatar
You can run the waste gate with a lighter spring and fine tune where you want your boost to ultimately be. You definitely need a secondary boost gauge and an AFR gauge. This will help reduce the aw sh*t moments.
Old 10-05-2016, 11:43 PM
  #34
raleighBahn
raleighBahn's Avatar
I would open the Tial and check which springs are in there (they are color coded), or maybe better, hook some air pressure up if possible and see if it actually opens (where it should, or at all).
Quick Reply: Testing TiAL F38 WG in single port mode. Smoke and oil everywhere.
