Limits with factory IC?
Professional Hoon
Cut the story short, I have a 924 project that i plan to frankenstein with a mix of cgt and gtp body parts with. And the engine will be getting some big boost.
I know i probably will not achieve over 400hp out of the engine. But will the stock IC with modded end tanks be sufficient enough for track days? It will have proper ducting to it also.
One serious racer here in Sweden with a very Quick 951 has the stock IC with about 430hp. It has modified end tanks and ducting like the 968 TRS. He keeps up with 997 cup cars.
I did 444 ft/lbs of torque with my 3.0L with the LR stage 2 at 15lbs boost running Petro Canada 94 octane.
We didn't have any fans blowing on the car either. Was a hot day too. Guessing you would mod the end tanks in the same way.
Professional Hoon
This is just in the making. Thinking a few things though.
The car is already on the hoist. There will be a fair amount of body work. As it use to be brown, now it's black... and it was a **** spray job.
Professional Hoon
I might do one on the PFA.
and probably 924.org.
At the moment i've just go it on the hoist and it will be a weekend project. It will take a long time.
I guestemate i wont make more than 350rwhp out of the engine. with a lot of ducting also.
Professional Hoon
Bonnet vents isn't a big deal at the moment. they'll be there.
At the moment trying to plan what i can use and what i shouldn't use.
Where should i spend the money first ect.
