I need clarification on testing O2 sensor with meter...
I want to test my O2 sensor. Clarks garage says"1.Start the car and run until engine is at normal operating temperature.
2.Disconnect the O2 sensor and connect a voltmeter to the sensor plug."
there are thee pins on the sensor plug. which ones do I test on? I searched and found it is possible to blow the fuse for the fuel pump if I use the wrong pin but couldn't find which are the correct ones.
Sure, you could attempt to check the that the O2 sensor is generating voltage by testing it with a voltmeter, but your average voltmeter will not give you much information. You might see a reading that oscillates between about 0.200V and 0.800V, which would be normal, but you might only see an average voltage of 0.450V or so (which a lot of voltmeters do when a switching signal is present). Either way, it won't tell you much. You really need an oscilloscope to accurately check O2 sensor voltage.
Chris
An even better test is to check the voltage at the DME connector itself!
