Overboosting - did I shim too much?
Go to the Lindsey Racing Web site. They have a step by step procedure with pictures for bypassing the CV. Go to the 944 section, then look under wastegate for installation instructions.
Booooooost
CV is now bypassed and I was getting 9psi, so the Reliaboost had to be wound back in 6 times and now I get a solid 15psi in 4th gear, just dropping back to 14psi after 5000 rpm
Thanks for all your help guys, you're the greatest
Asarus if you still need pics I can email some to you if the one's above are not enough
