Transaxle stabilizer
Old 07-29-2016, 02:07 PM
disasterman
disasterman's Avatar
Default Transaxle stabilizer
These supports were added to combat transaxle twist during acceleration. We are regularly experiencing torn boots. Eniac's shop - Autocore, hopes this will be the fix.
Will let you know.
Old 07-29-2016, 03:09 PM
blown 944
blown 944's Avatar
close to what I have ran but different angles. I use one on the driver side and one at heh rear that goes to the passenger side
Old 07-29-2016, 03:27 PM
v8killer
v8killer's Avatar
Does the Lindsey solid mount help with this?
Old 07-29-2016, 08:49 PM
333pg333
333pg333's Avatar
Any restriction should help including trans mounts, but I wonder if making it totally solid as such would have any negative effects? Old pic of ours.
Old 08-01-2016, 01:08 PM
disasterman
We shall see. I did not design it but we are not running crazy horsepower here. The trans mount is a Kokeln.
A solid mount is not enough to prevent transaxle twist of high torque engines.
Old 08-02-2016, 06:42 AM
mikey_audiogeek
mikey_audiogeek's Avatar
Hi disasterman, what's causing the transaxle twist? In theory all the torque reaction is taken out via the torque tube, so there's no torque reaction - unlike a "normally" mounted drivetrain.
Is your torque tube flexing?
Cheers,
Mike
Old 08-02-2016, 09:05 AM
disasterman
There has to be movement through the entire length of the drive train including the shaft. The solid transmission mount is relatively small and does not provide a lot of stability for higher horsepower/torque. It's more of a hanger than a bracket. A contributing factor is how rigid the entire chassis is at the rear highlighting the weakness of the transaxle mount. Patrick has more experience documenting the twist on his higher horsepower build.
Old 02-22-2018, 11:25 PM
boost feen
boost feen's Avatar
The factory had a solution for this in 1981-1982 for the new Audi based 5 speeds perfect fit for all 5 speed transaxles in a 944 I use one on my 944 and the early 944s use 2 mounts on each side somonce you add this one you have 3 mounts making it very stable. This bolts to the transaxle with a few longer bolts where steel gear case meets rear alloy tail section.
Old 02-25-2018, 11:29 AM
mj951
mj951's Avatar
Nice find boost feen, could you share a photo of it installed. TIA!
Old 02-25-2018, 12:00 PM
Dave951
Dave951's Avatar
+1 Photo. Also what cars had that transaxle support or what is the part # on it?
Old 02-25-2018, 01:50 PM
mj951
mj951's Avatar
Edit: I'm pretty sure that was the wrong part and diagram...
Old 02-26-2018, 01:46 AM
boost feen
boost feen's Avatar
Here’s a picture of this factory bracket installed in car it goes over the muffler and bolts up to chassis with a large 1.5” or so diameter rubber mount you could use poly as well for stiffer mounting I like the rubber it firms up the drivetrain a lot when cornering on track helps in shifting. I have a extra one if someone wants to buy one doesn’t come with rubber mount just the alloy bracket in my pic you use a few longer bolts to mount it to any 944 gearbox. $100 shipped conus
Old 02-26-2018, 02:02 AM
mj951
mj951's Avatar
Thanks for the photo boost feen...i'll take your extra bracket. Will PM you tomorrow with shipping details and to work out payment.
Old 02-26-2018, 06:55 AM
ealoken
ealoken's Avatar
Can you read any part number of that?
Old 02-26-2018, 09:02 AM
Voith
Voith's Avatar
+1 also interested in one.
Btw: thanks for information, never knew this existed.
Quick Reply: Transaxle stabilizer
