Transaxle stabilizer
#31
I could be wrong, but I think that the entire driveline is going to move fore/aft under acceleration, braking, shifting, etc. This becomes very apparent when the mounts are getting old or soft and you can feel the entire car shudder when shifting or starting from a stop.
Maybe fresh, new mounts are enough to bring this to a negligible amount, I do not know.
#32
...I could be wrong, but I think that the entire driveline is going to move fore/aft under acceleration, braking, shifting, etc. This becomes very apparent when the mounts are getting old or soft and you can feel the entire car shudder when shifting or starting from a stop....
#33
MAGK944, nice find in PET thanks for posting.
Also, French Toast thanks for chiming in, I think you're bringing up a good point.
I was planning to do the Urethane Transmission mod but rather liked the idea of an OEM brace.
Since this piece was never meant to be a transmission brace I think further design for that use is wise. It seems to be working well for boost feen and i've seen similar braces on here using spherical ends and a bar stock solid brace. I believe a lateral brace will improve shifting performance and help limit over extending CV joints from to much lateral movement of the transmission case. Since the transmission and engine act as one in the chassis it seems logical that allowing similar movement at each end will suffice. That being said what do we think of using a rubber anti-vibration mount (Lord Mount) mounted to a MM mount as shown below. I'll need to take a closer look at things once i have the brace in hand but with a fixed connection at the transmission case i think we're looking for a mount at the chassis that allows a similar amount of movement as the engine mounts...?
Might also include thin rubber bushings between the transmission case and the new brace just to free up that rigid connection some.
Thoughts? Other chassis mounting ideas?
#34
Rainman
if you look at the early model 944 trans mount there's no chance that trans is moving fore/aft, only up/down or twisting along its axis.
the late model banana-hammock is so floppy that it probably *could* move fore/aft but i think it's pretty well secured at the front end to prevent that.
#35
I'm not very familiar with early cars but after looking at those mounts I think you're right.
Any movement at the mount is very small, measured in mm's at best but I also agree with French Toast that a completely rigid mount is not ideal...question is how much movement is useful / acceptable? I think your urethane mod is a good one and i will probably still complete that as well as mount this brace with some type of rubber bushing at the chassis.
This will be my first time dropping a transmission so should be fun, lots of cleaning and other while you're in there projects to complete.
#36
Aircon anti vibration mounts would work here and have at least 5mm give in all directions.
#37
If anyone is interested, a friend of mine in the UK can supply the hanger and 2 new bushings for $135 delivered if anyone is interested. Let me know. The top bracket if you want/need it would be another $15.
