LR Fuel Rail/Remote FPR
Have 3 of them. All work well. Newest one is the best of the 3. Peoples issues with the 2 post in my opinion is they were not installed properly. My 2 post never gave me any problems. There were 2 versions of the 4 post. Newer one is slightly shorter on the damper end.
The older 2 post rail did not work for me so I purchased the 4 post which worked out much better. The remote fuelab works great, no issues. You can install a gauge minus your cruise control motor but it's in a good spot there. The marren damper is too long on the rail. I never liked it that close to the firewall but if you have nice big wrenches you can get it shortened up a bit more. If I had a choice, the CEP rail would be ideal on fw space but the LR kit is solid. Just do not bend the 4 post legs on install or removal.
I had issues with the Fuel Lab regulator and took it off and installed an adapter to allow me to use a standatd Bosch regulator - I am using the Cosworth 3.5 bar version, not sure if this also fits the Porsche version. The issue was the Fuel Lab drops off pressure (by design) too quickly for my setup and this caused issued with hot starting. Other than that I really like the rail and I am also now running without the damper. I had my own lines made up using Pro Gold PTFE lines, these do not seep fuel vapor and also are not as abrasive against anything they touch. The fuel pressure regulator adapter I used was from Radium Engineering and also works well.
Given that 1) I'd like to keep the Cruise Control, and 2) I'll be running with the 3 bar FPR to go with the M-Tune setup - perhaps there is some consideration for using the LR product?
I've come to far to allow an OEM Fuel Rail ruin a good thing by initiating a fire type event under the hood.
Thinking this is the way to go Jay (adjustable FPR). I have a Bosch 3 bar FPR and am running M-tune but have had problems running rich and the only thing I can think of at this point is the FPR, everything else seems to check out good. Will know for sure after I get through the CA smog test and can start playing some more.
When I set mine up I did look at the saddle adapter but I could not tell from the pictures how it would work with the AN lines, so I went with the Radium piece. It also allows use of cheaper standard fuel pressure regulators at any of the standard Bosch ranges i.e. 2.5 bar, 3 bar, 3.5 bar and 4 bar. Maybe give Lindsey a shout and see if the saddle adapter works with AN lines or it you have to retain the factory lines.
