recommend me a clutch kit/setup
Old 05-15-2016, 05:23 PM
Ak951
Ak951's Avatar
Default recommend me a clutch kit/setup
After losing shifting ability while running, I replaced my clutch master and slave. I bled 3 different ways and couldn't get the clutch to disengage. I checked the inspection port and there was a good amount of movement....great. Looks like my pressure plate isn't functioning.
Now I'm looking into clutch kits....
Zims has the cup clutch kit for $550. How much tq can it handle? I'm going stand alone soon and would like to be able to hold 375-400wtq if I wanted.
Any comparible or better kits out there for the price?
Thanks!
Old 05-15-2016, 07:15 PM
lart951
Basic Sponsor
lart951's Avatar
Kep Stage I and 930 disc, talk to Jason at paragon parts
Old 05-15-2016, 07:19 PM
Ak951
Ak951's Avatar
I've heard good and bad things about the 930 disc....how much are you putting down?
I emailed Kennedy about their pp, didn't know paragon had them.
Old 05-15-2016, 07:32 PM
lart951
Basic Sponsor
lart951's Avatar
Two of my lartmobiles used these setup both over 350rwhp
Old 05-15-2016, 07:48 PM
pole position
pole position's Avatar
A properly installed cup clutch will hold 350-400 whp all day unless you are aiming to drag.
Very few 951' make a true 400 whp on a mustang .....Dynojet numbers are inaccurate vanilla sky promises
951's are notoriously over clutched with ridiculous 6 pucks and other associated non sense
best combo is if you are shooting for big up/TQ numbers use a cup pressure plate and re face your existing disc with organic / feramic by Southbend
Old 05-15-2016, 07:54 PM
Ak951
Ak951's Avatar
Thank you!
I'm going standalone and twin scroll bigger turbo....shouldn't have a problem hitting 400, but don't really have a need to go that high...just in case
Where can I get a cup pressure plate?
Old 05-15-2016, 07:55 PM
944hal
944hal's Avatar
I've used a KEP PP with a stock Sachs clutch disk for years without any issues. Just to clarify, it's a 951 track car.
Old 05-15-2016, 07:57 PM
Ak951
Ak951's Avatar
Keep hearing good things about kep...who sells them?
Old 05-16-2016, 03:37 AM
lart951
Basic Sponsor
lart951's Avatar
http://www.kennedyenginc.com/Pages/default.aspx
Old 05-16-2016, 05:13 AM
Voith
Voith's Avatar
What would be a good clutch disk in standard turbo S pressure plate and fylwheel but in 600whp range?
Old 05-16-2016, 11:59 AM
mtnman82
mtnman82's Avatar
Ak - +1 on the KEP pp and 930 disk here. Pretty much stock pedal feel. I'm putting down a little over 300whp/wtq. Stick with the stock flywheel if you go with this combo (I had mine lightened to 9.5 lbs and dig it, others not so much).
Old 05-16-2016, 02:19 PM
Bladed-vaults
Bladed-vaults's Avatar
Im running the spec stage 3 both PP and disc. Ive seen a few bad reviews on the spec discs here but I have had no issues at 310whp. I got the car with the same kit and I replaced with it so I cannot comment on pedal feel that kit is what I am used to
Using the 7.5lb billet FW btw
Old 05-16-2016, 02:39 PM
pole position
Feramic/feramic good drive ability life expectancy 10-15 k miles
Quick Reply: recommend me a clutch kit/setup
