Engine pictures
Engine pictures
I think we have one thread that have all engine pictures from lot of us. I could not find it now. Any help? I have problem to install my new cone intake. Thank
you may have confused a cone filter replacement for the stock airbox w/ map/maf kits you see in the pics. the map/maf kits will put the filter behind the drivers side headlight. the airbox replacement type (kokeln is the one i have) will keep the AFM in the stock position and the filter attaches to then end. it sits perpendicular to the motor above the belt covers
My mechanic wedged a thick (0.75 inch) rubber grommet between the K&N cone filter and the headlight assembly arm to ensure a tight fit and no banging around. My headlight sometimes vibrates a bit when it is in the upright position, otherwise works pretty well.
