Help Identifying a Wire
Gents,
My headlights stuck in the up position yesterday and I went to investigate and found a wire that is wrapped around the headlight bar.
Can someone help me identify this wire? I think it has my headlight bar bound and I want to know what it is before I start cutting it out
Thanks to anyone that can help!!!
![Name: 2016-05-02 09.53.39.jpg
Size: 334.1 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1046745d1462198376-help-identifying-a-wire-2016-05-02-09.53.39.jpg)
It's going to be hard to identify the wires based on that picture. Try peeling away the tape covering the wires so we can see the size and color of the wires inside, and also try to take a picture showing which harness bundle it comes from. Looks to me like it could be any number of things, including old AFM wiring cut and spliced for a MAF conversion. Speaking of which, that blue coupler is ripped in a couple of place, and definitely should be replaced.
It's going to be hard to identify the wires based on that picture. Try peeling away the tape covering the wires so we can see the size and color of the wires inside, and also try to take a picture showing which harness bundle it comes from. Looks to me like it could be any number of things, including old AFM wiring cut and spliced for a MAF conversion. Speaking of which, that blue coupler is ripped in a couple of place, and definitely should be replaced. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks for the nudge on replacing the blue coupler, it was rubbing against the headlight lever which caused the damage. I repositoined it but need to replace the coupler
Yikes, that's a ribbon cable -- for use inside computers and other electronics for very small currents. It's not something I'd ever use under the hood, though it's possible some MAF kit used it. Porsche didn't put it there. Keep peeling back the tape and see if someone spliced that into a factory harness and/or where it connects.
