Problem installing 3" downpipe
Iīm installing a 3" downpipe and iīm having trouble tighten it properly.
Itīs so tight between the nut and the downpipe so iīm slipping on the nut.
( I first tried to remove the studs to use allen bolts instead but couldnīt move the studs).
Must the downpipe flange go flush with the turbo flange or is a small gap ok when using original crush ring?
