Finally after a LONG wait my 3L hit the dyno
#31
#32
Rainman
Just in the past the question has come up around here about what size pipe is needed for what HP level...that the stock pipes may be too small or wrong shape or whatever.
But here you are dumping 500+hp through them...so they're just fine.
#33
Originally Posted by V2Rocket
Not like that lol.
#34
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
We have discussed this a long time offline, I am dying to see the chart myself, but not forthcoming. This is frustrating to say the least, but is what it is. With this not being a DBB turbo, I am slightly worried about an on/off car that is a bit laggy, but the displacement might make up for some of this. The chart will answer many questions.
#35
Yes it is a 3 liter but STILL 8v. Would love to know the rpm it hits this power at.
I think the build is a good platform to ask questions on. How would the exact engine change is one element was changed.
16v instead of 8v. more rpms on same turbo. Different turbo smaller or bigger. All things the same but stroker. Lot of things were done well with this engine. I like the compression.
Again I think this engine with the dyno chart can tell us a lot. It is making good power. Like Patrick said a few days ago, we have several engines getting built lately 16v but also 8v that we can compare and contrast and get a lot of good data. Would also like to know what gas was used on this and the engine management.
Again congrats on a big strong engine, Would love to see videos on it. Drag it a few times.
Last edited by AlphaOmegaPower; 04-09-2016 at 06:12 PM. Reason: modifying, spelling
#38
1 Post
TEC-S can do sequential with supporting mods, but not done on this car. Yes, boost is very high for pump gas, and the low C/R is a built in Nanny for boost happy youngsters.
#39
25 psi is way high for pump gas. I personally would not run over 16 psi with 93 octane. Is the hp being measured at the wheels or are we backing into a crank equivalent.
#40
1 Post
The car laid down 470 HP on a Dyno Dynamics which is within 1-2% of a Mustang at 22psi "Supposedly" again No chart. Chart is supposed to be delivered soon, I am eagerly awaiting its posting.
#41
Thought engine building was about what one wanted.... Not what others tell them they should want.
Hopefully that low compression doesn't cause people to get nasty like always seems to happen in these threads.
#42
wow, serious power, congrats.
#43
470@ 22psi and 560 @ 24psi? Was it 470 wheel perhaps and this is estimated 560 at crank? That would make more sense. If it's meant to be 560whp on 93 oct at 24psi I'm somewhat dubious. Nevertheless, hopefully it's all good now and the owner can get some enjoyment out of the car.
#44
#45
Psi is irrelevant unless you're stating the entire engine/turbo/etc setup. There is no universal 'don't run about this psi' rule of thumb that applies for every engine/displacement/head/turbo/fuel/etc. Maybe if we were talking about stock engines with common variables, but we aren't.
