Finally got my favorite Porsche! Need advise please!
Old 03-20-2016, 04:42 PM
87nine5one
87nine5one's Avatar
after several cans of degreaser and brake cleaner.......I'm actually starting to be able to see the block!
More cleaning and removing of the front engine parts
Getting there.....
the roller on this tensioner was so shot you could spin it in your hand and it would just keep spinning, I don't think this was EVER changed!
All cleaned up and painted
Old 03-20-2016, 04:54 PM
87nine5one
87nine5one's Avatar
this alternator was rebuilt at some point in its life, time to be cleaned and painted!
seeing how nice this will eventually look once all the grim is out and off!
this is how I knew the alternator had been rebuilt, I pulled the sticker off to paint it.
cleaned the intake in and out and sprayed it to look better
cleaning of the cam tower prior to pulling the cam out
painted and testing to see how good it will look in there once she's done thinning out my wallet
fuel injectors had bad o=rings and the end caps cracked when I tried to removed them, so the obvious thing to do was to clean them up too, used the factory black color to repaint them
At this point the engine is a lot cleaner and deciding whether to pull the motor, just pull the head, or drop pan and head and re-ring and change bearings, decisions-decisions
flushed the block, surprisingly nothing came out except some very green antifreeze, guessing that's a good sign
I hand painted the letters so I'll have to do another coat or two before I clear coat the cam tower, I think it came out pretty damn sweet!
The brake booster vacuum line snapped like a twig when I tried to move it to clean under it, that Lindsey hose kit is looking better and better!
It's actually starting to look really good now that majority of the crap has been cleaned off!
Old 03-20-2016, 05:10 PM
KVDR
KVDR's Avatar
Wow, you've made good progress - How long have you been at it?
Old 03-20-2016, 05:18 PM
87nine5one
87nine5one's Avatar
Thanks! I've been doing a little each day since I got the car the beginning of the month, biggest pain is that every part needs to be shipped to me! The majority of the work I've done has been over the past two weeks, since I got the tools from arnnworx, which have made this 100% more doable! Biggest thing was locking the flywheel
Old 03-20-2016, 07:29 PM
87nine5one
87nine5one's Avatar
Some more progress so far today, need to get some hardware from lowes to pull the crank gears with my puller, but here's some pics of the upper balance shaft cover removed to paint and change seal:
Upper balance shaft looks pretty good, the onion peel is there and the front bearing area seems smooth
Oring looks shot, no surprise, the front bearing looks ok, do we change these? The front seal is a Kaco brand, safe to assume it's been changed before? Do we normally change the seal sleeves as maintenance?
What are your thoughts on this inner bearing?
Cleaned ready for some paint!
Old 03-20-2016, 08:16 PM
E-man930
E-man930's Avatar
Join the Facebook 944 turbo group - lots of motivation and tips from Rennlist Members and it's way more responsive...
Old 03-20-2016, 08:39 PM
87nine5one
87nine5one's Avatar
I only see one for FL/GA and what seems to be the UK, is there one in particular?
Old 03-20-2016, 11:10 PM
E-man930
E-man930's Avatar
Join the GA/FL group and post an intro and I'll add you to the main 944 turbo group.
Old 03-22-2016, 11:59 PM
87nine5one
87nine5one's Avatar
Sounds good, I'll join it in the am,
Old 03-25-2016, 06:56 PM
87nine5one
87nine5one's Avatar
Default So I've decided to continue disassembling the engine to see the condition.....
Here's where I'm at, what does everyone think? Re-ring? Keep going? Head gasket I removed was a reinz, so it's definitely been changed, cylinders 2 and 3 look pretty good for unknown mileage and maintenance, what are your opinions?
Old 03-25-2016, 07:08 PM
87nine5one
87nine5one's Avatar
Old 03-25-2016, 07:30 PM
87nine5one
87nine5one's Avatar
Should I use valve compound to clean these up more or do you think they look good as is?
Old 03-30-2016, 12:03 AM
87nine5one
87nine5one's Avatar
Think I'm going to have the guides replaced, need to find a competent shop that can do this head correct. Also found my 2-3 header has a crack in the flange on the 3rd cylinder, guess I'll be looking into new exhaust as well, gotta love it the pit continues to decend deeper!
Old 03-30-2016, 09:44 AM
CyCloNe!
CyCloNe!'s Avatar
wow looking good... love the porsche center wheel cap in the turbo outlet
Old 04-11-2016, 11:09 PM
87nine5one
87nine5one's Avatar
Thanks! The wheel cap is supposedly good for 20hp/20tq
Quick Reply: Finally got my favorite Porsche! Need advise please!
