Just another low boost issue...
I second what Mach5 said and will ad to check for a collapsed cat pipe etc. They have been known to do this and cause a very similar issue to what you are describing. I am helping a friend with almost identical issues, however his car is now chipped.
Have you tried driving it without any boost control, MBC or cycling valve? You need to be VERY careful not to excessively overboost (although I think you still have a stock ECU which will shut it down). This would tell you if the system is capable of producing more than 6 psi boost. If so, then it has something to do with your controller. If you still only get 6 psi, you may want to look for exhaust leaks pre turbo/wastegate.
Roger
Roger
Any way to check the crossover pipe without removing it?
