944 turbo internals into 928 build
I know the 944 motor came from the 928 motor but are they identical?
Was curious if your could take the 944 turbo rods and pistons and build a 928 motor and do a big turbo or twin turbos.
Never seen it done so I was curious.
No. The 928 rods are different widths and height then the 944 rods. But you can still build a 928 twin turbo. Best company to talk to would be 928motorsports.com that I know of for 928 mods. http://www.928motorsports.com/parts/...aft_keyset.php
Rainman
Yes, guys use 944/951 pistons in their 928 engines frequently as the bore and stroke is the same in their 5.0 engines.
The 928 rods are the same length and dimensions as the 944 rod, except for on the big end where they are machined with an "offset" of a few millimeters because 2 rods share a crank journal.
Some guys have used 2 sets of 944T rods (since they are very strong) and machined them to fit the 928 crank.
The only issue is that the 928 has a 2mm higher deck height than the 944, so at TopDeadCenter, your 944 pistons will be 2mm shy of the 928 block deck, so you will have lower CR...but a lot of valve clearance!
Professional Hoon
Don't understand with all the work making the 951 rods fit, shouldn't you just buy a set that's made for the 928 that's lighter and stronger and also not 25 years old
Rainman
Imagine paying twice that
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
The 951 rods are much stronger than anything the 928 was ever fitted with, and in a 928 engine they will see less stress per HP because twice as many rods to share the load...
Professional Hoon
I wouldn't go all that way building a 928 engine to put in used rods from a car with who knows how many miles and condition of them ect.
Yeah, that rhetoric...
Some may consider my budget 2.5 16v turbo build also nonsense ("why own such car etc") yet it works that way and some people succeed and some people don't.
You know you can check the rods for hairline cracks etc before putting them into engine, right?
Annealing would probably help, removing internal stresses. My understanding of shot peening is that it cold works the outer surface, making it harder and less likely to crack (entire surface is actually slightly in compression).
