Power window issues
Power window issues
Hey all, yesterday my power window on my drivers side stopped moving. Only issue is drivers side, passenger side works great from both switches.
It's stuck in the down position covered by the door panel. When I push the switch to make it go up I can hear the motor wind and I can hear the window try to move and make noises. The window will move up about 1 inch until only a cm or so sticks out above the door panel. I pulled the switch assembly and both switches were secured and fine. Assuming it's a motor problem or problem with window gears. Any advice here?
Never mind, after a few hours of toiling over my stupid window issues I found it was completely out of the tracks and the regulator arms were out of the channels they were supposed to be in. Managed to get 3 out of 4 of the arms in the channels and can't get the last one in. Turning it in to my shop in a few days!
