Need help understandig my two latest engine failures.
#46
Didn't realise you had the MiDs. Who installed these? We ran into similar issues some years back and concluded that they just didn't work due to incompatibility with piston / rings and these sleeves. There have been a few recorded cases where you can read about successful motors so they must work. In the end I have to agree that it comes down to the installation of the sleeves as well as potential incompatiblity with some of the components. If your sleeves weren't installed by someone that has done these many times before then it's highly likely that this is the cause of your issues and no matter what you do (including setting massive clearances which we tried) you won't ever resolve this. Your block may well be toast.
#47
This.
#48
I don't think it is the parts that is the problem, it is the honing of the sleeves, you need a machinist with the correct setup for installing the sleeves. I've run mine well past 700hp...
#49
We used a local machinist who hadn't installed Darton MiD sleeves. We were assuming there was a parts incompatibility and I still think there may be something in that, however I have since turned my eyes to the machinist. This was in 2007. It's block preparation, not just the honing from what I understand. Changing block temperature at various stages of the installation is meant to be crucial.
#51
Installing the sleeves correctly is an art form. Each step requires cooling prior to going to the next especially when it comes to seating the sleeves (which need to be done individually) and prior to machining.
But from the pictures and his description the sleeves do not appear to be his problem.
#53
Have you seen any indication that you are pressurizing the coolant system? If the sleeves weren't installed correctly you can get a bit of movement which can allow coolant to get into the combustion chamber and gas to get into the coolant.
This could cause some issues with the rings, however, after only 40 miles my experience tells me you likely didn't get the correct piston/cylinder wall clearance and probably didn't get the correct ring end gap set and possibly didn't get the rings gaps for the compression and oil clocked in the pistons correctly. If you had the correct rings for the sleeves and they were installed correctly you simply would not be getting a lot of oil smoke or oil consumption in the first 40 miles.
I found the Darton MID sleeves with the JE pistons needed close to .006" clearance to work properly. The Wossner pistons may have a different thermal expansion than the JE pistons.
#55
Reversing the pistons would have no effect on symmetric skirt pistons, even with an offset wrist pin. Many pistons don't have offset wrist pins anyway. If the pistons were installed backwards it's more likely to hit the valves.
#56
Whoo who! now I'm not worried about my last engine. JK.
#57
Thanks for all inputs!
No indication that I was / am pressurizing the coolant system. No loss of water.
Not yet. I will post here when I do.
Darton wet sleeves. Normal driving on the street, low boost. Sorry, I do not know side clearance on the rods.
#58
#59
I would recommend following Shawn Deal and Sid's 2.85 Hybrid stroker build. It is well documented and that is what I did. The motor makes for a very strong Street build. At 10 psi I'm keeping up with 400 hp AMG's that are V-8's with lots of torque
#60
Hey guys,
sorry for bumping this old thread. Was there any solution so far? I am having the same issues (oil in combustion chamber at the cylinder walls and at the intake valves) but no klicking like here. Intake is dry, turbocharger is dry and engine was completely rebuilt 3500 km ago. I wonder if 964-C2 found out the cause of these symptoms.
Regards, Oliver
Regards, Oliver
