How to test bypass valve
Hi, I tried to my mityvac to test the valve, but as it is not installed, am not sure the best way to test it. Do I cover the large two holes and pull vacuum on the vacuum nipple? What should I be seeing?
You can suck on the nipple and it will open. It should hold open until you let go of vacuume. This is for a stock valve or an aftermarket with the same weight spring.
The vacuum signal test is good, but you should also check it under positive pressure - at least the amount that your wastegate will allow. The early bypass valve with the 951 part number had a plastic diaphragm and could more easily fail. If yours is the more modern 993 part, It is more robust.
Apply 1 bar to the turbo outlet side of the valve to ensure that it holds.
That test worked thanks.
The cool thing is that on the new valve I can blow into one of the holes to add pressure, then pull some vacuum with my mityvac and it makes the blow-off sound. So basically I can walk around my house doing that and pretending that I am a 400 hp wrx.
