Originally posted by Wormhole I don't think anything post 86 will work. The part number is 951 331 021 01
Hi John,
I PM'd you back. While the number you posted is correct according to pet, the part number cast into the arm I have is 951.331.513.0R I also compared this to the driver arm on my 86-951 and it is the same. Is the number you posted cast into your original arm?
Rob, I got the part number from PET, so the part number you have is probably the correct one. As long as your using spacers to fit the late style twist wheels you have in your avatar, then I think you have the correct number. I’ll double check what mine say tomorrow.
