Rogue M-tune correct installation ?
I am working with a 1989 951 with Rogue M-tune Maf-kit. Current owner bought this car recently and MAF kit was installed by a previous owner. Can any of you give me a piece of advice concerning this MAF kit.
-does kit use stock cyclic valve
-if not should hose connect between IC pipe and wg
-does kit's MAP sensor control boost pressure
-how boost is adjusted in this kit, looks like it is now 1,2 bar
-idle is not prompt. revs drop when throttle is released to 1200rpm, then it jumps around 500rpm up and drops again to 1200rpm and then to idle
-is anykind of installation manual available somewhere
