WTB: single 3.0 16V piston
I got the 3.0 16V piston delivered for free from sherry66.
Sherry66; Thanks man! If you ever need anything, let me know!
Ive roughly calculated it to be something in the neighborhood of 8.2:1 with 1.5mm thick HG and 968 head.
Andial / Mahle 3.0 8v turbo pistons are not really 8.0:1, closer to 8.5:1 if I remember correctly.
Target CR is 8.0~8.3:1.
Here is the stock shape:
Completely separated twin scroll EFR turbo should kick in sooner than stock turbo and give back some of what is lost with lower CR. (my theory, could be wrong)
I have all versions of 8v heads, 968 head and most of piston types now. I must take some time and cc everything.
Rainman
which way should the piston be oriented in the bore?
should the flat, raised portion (not the dish) be on the exhaust or spark plug side of the cylinder?
i would think it should be on the exhaust side, so the flat spot matches up to the flat spot on the head as the dish matches the head chamber pretty well in shape. D shaped dish, D shaped chamber, shouldn't the "D"s line up?
Ds do line up. Flat side of D is the exhaust side on 8v.
Just CCed both pistons..
Both are Mahle and both look very similar design, height etc.
104mm 3.0 16V NA= 27 ccm
104.5mm 3.0 8V T= 33 ccm
Rainman
What are the power goals preventing you from running the 16v NA pistons as-is, or maybe machining the bowl a little more?
For 6 cc it might be half a point of CR?
Running math again, how are you getting those CR numbers?
Using the SummitRacing CR calculator, all-stock 944S2 info (104x88, 42cc chamber, 0 deck height) but 1.5mm gasket, puts CR at about 9.5:1...and your 8v pistons are 10:1.
You sure you aren't plugging in 8v chamber by accident (56cc or so)...that would put the S2/8v pistons at 8.3-8.8:1 respectively.
I did my calculation like this but deck height is just guess, I have no idea what will turn out since the block was decked. Ill probably compensate with HG thickness or if machinist wont complicate things complete bowl will be machined slightly deeper.
This is 10cc. I am bending plexi a bit with finger here, so water level is a bit higher than it should be.
Machined piston should get +/- 10 extra cc, making it ~43. For some reason I thought it was somewhere around 0.5 below deck, but just checked it and since my block was decked, it should even stick out a bit. Damn. It'll be hard to get much below 9:1.
Same calculation with deck clearance + 0.20mm is 8.819:1
