Car is Stalling, Idle valve or vac leak??
You mean the speed reference connectors were repaired connectivity wise. I have been told by Danno to use high temp glue and place them in the slots. Then you can heat sink them if you like. Its very likely that that area gets very hot very fast. They are expensive to replace too 100$ plus for each one. You might find a good priced used one from German Car Dismantlers. I know last weekend I saw several Turbo ones which were in good shape. I had planned on going back and getting them for myself if the Glue and Heat sink method does not work out for me.
