my new 3.0L
I have Never saw one before either, and this dam I phone sucks. I assumed most of you guys on the form have seen one, once it's on will update photos
5866 with .68 AR where to small on my 3.0L 16V (stopped at 410whp). I would use a 5866 with 0.82 AR, both T4 housing. I think the 62 compressor housing is to big unless you want massive HP
Beautiful engine!
It seems you installed the engine from the top with the hood still in place? I have recently made a cornerweight and wheel alignment and if it is possible to remove out top that is tempting for me so I don not have to ruin my setup.
Please advise as to what is needed to remove/install from the top.
Kind regards
Peder
Kind regards
Peder
Devon, with all the money you are spending it may be time for a new coolant reservoir!
May be the angle the engine is on the stand that is throwing off perception. I don't think there will be an issue with clearing the hood. Maybe a strut bar though..
It's very easy with the headlight-bar removed. Even more clearance if you remove the crank-pulley and radiator. It's easier with a balancer to allow you to angle the engine and change that angle as it's lowered. Although in this case, it appears he keeps it flat the whole time. I find it's simpler and faster to do a clutch-change by removing the engine rather than disassembling the drivetrain from the back forwards. Repair-book rate calls for 16-hrs on a 951, I can do it in 7-8 hrs without rushing. I found a post where Kevin Gross removed a 951 engine in 1,5-hrs.
You got PM.
/Peder
yes i am a power freak, like i said before it will be a highway monster ! i am hoping for big number will be dynoed in about 2 weeks
once i get the car back i will be ordering it i know its so nasty. still so much more i want to do well need to do it never ends
