my new 3.0L
Well it started from my blown up 2.8l ...
JE 104mm pistons
Sleeved
968 crank
Pauter rods
Oil pan baffle
Lightened crank
Major port and polished head
Bigger intake valves
Springs retainers
Custom grind cam
6266 turbo charger
Custom intake manifold
F46 wg
3 inch turbo back
Rouge m tune , dme tuner and logger
1600cc injectors
Greaddy ebc
044 pump
Might be missing some things
Looks great! Like the cambox paintjob. Something different. Let us know when they dyno it.
the car is not a track car , it is going to be a highway monster so a 3rd gear pull should not be an issue also thee 5858 or 5862 will not achieve 500 wheel i was told. anyways with e 85 and 22psi f boost i should be i HOPE
You should remove the boxing gloves before you type...
Haven't seen their intake before. I suggested to them that they come up with something, so show yours when it's done.
