Will a 968 60-2 wheel fit on a 951 flywheel?
Justin you might be correct, I have Micheal Mounts, SFR, Chris Whites and Clewitt's all installed or around here somewhere. I might be getting confused with them all. For a fact the SFR is clamp on and MM is bolt on.
This is one from that company I mentioned previously.
Patrickmotorsports was easy to deal with and quick to make and ship it. Cheap it wasn't. But it has worked easily and reliably.
Yes Rich. I've kept that pic on file for such questions. Hope you don't mind.
I have an S2 flywheel, clutch and bellhousing if you need any of that stuff. The clutch I suppose you would have made to spec though.
Another possible source, all I know is what is in the link.
http://ttvracing.com/product/porsche...cturer=porsche
Re the photo, it appears that Patrick Mtrspts is machining the 60-2 teeth into a 951 flywheel. Nice approach! Also, pretty simple with a rotating fixture on a Bridgeport.
Does your post imply that you are wiling to make me one
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
