FS - 1987 944 Turbo - 96k miles, Vitesse Stage 3R, LSD
UPDATE: I am now offering this car up for $11k FIRM. I will be back in the SF Bay Area on March 11th-21st and can meet with potential buyers. I have moved out of state, but will do my best to answer your questions. Best way to get in touch is email at dstupakov [at] gmail [dot] com.
Preference will be given to buyers who can pick up the car in person - I will not have time to deal with shipping arrangements while in CA.
If I don't sell before March 21st, the car will be shipped out to the mid-west and then parted.
Only trades I would be interested in would be for a clean 1994-2001 Toyota Land Cruiser with the locking diffs.
Unfortunately won't have the garage space or time to continue my project so I'm thinning the herd. Trying to sell everything as a package if possible. Overall great example of a well modified, low mileage (96,250) and desirable color combo late model 951. Big binder with nearly 50k in records. Very straight body, paint and interior a solid 7.5 out of 10. Dashboard is cracked. The car is running and driving but not California legal. Needs wiring work and someone good with a tuning laptop to finish the last mile. Out of state buyers should be able to register this car with no issues, but I couldn't pass California's NOx limits with the stealth setup, and couldn't pass visual with the Vitesse intake. The car has been driven about 15 miles in the past 3 years - so I can't speak to its reliability at this point.
I had an awesome time owning this car and it ran great while I was still driving it. Pulls 18-19 in/hg of vacuum at warm idle. Will break the rear tires loose and throw flames at 15psi (I never ran it higher than that).
Located in Cupertino, CA. Asking $11,000 FIRM
You can find more photos HERE.
Factory Build Sheet:
Paint Code: L90E Alpine White
Black Partial Leather Interior
Options:
220 LSD
341 Central Locking
418 Side Moldings
437 Electric Drivers Seat
454 Cruise Control
650 Electric Sun Roof
946 Leather Seats
Drivetrain:
- Vitesse Stage 3R turbo + V-FLEX MAF + VRT8x piggyback (I have a stealth MAF setup also available to try CA smog).
- Zeitronix ZT-2 Wideband Monitor and Display
- Lindsey Racing 3" exhaust. Comes with 3-way CA cat, 2-way race cat, and straight pipe.
- 930PP with Sachs Sport Clutch (~6k miles)
- New clutch master and slave cylinder
- LR dual port wastegate
- LR HV fuel pump + SS fuel lines
- LR silicone hoses
- LR hard pipes (currently not installed w/ Stealth MAF)
- 993 BOV
- Saikou Michi oil catch can
Suspension / Brakes:
- 2005 997 Carrera III wheels (18x8 / 18x10) w/ Bridgestone RE050 tires (70%)
- Big Red front calipers + 965 factory rotors
- Koni adjustable shocks F+R
- Weltmeister Lowering springs front
- Re-indexed torsion bars rear
Exterior:
- 968 Mirrors
- 968 Door Handles
- Turbo S script decal on fender
Interior:
- 993 steering wheel + 996 clock spring
- 968 8 speaker door panels
- 968 Clubsport center console
- Boxster CR220 radio, faceplate modified for 944 viewing angle, with iPhone 30pin aux input
- Suede shift boot + aluminum pattern
The not so good:
- It does not pass California smog currently. Registered as non-op. A new catalytic converter or tuning to E85 could get it to pass.
- My tune with the Vitesse is not perfect. Included are all the Vitesse Manuals + software.
- The Vitesse piggyback wiring was not done very well. It should be re-done. I have DTM connectors and have the wiring diagram for the piggyback / wideband / map sensor harness.
- The lower balance shaft is leaking oil.
- The back of the cam tower is leaking a bit of oil onto the headers.
- The front speakers are currently not installed.
- The caster block bushing on the drivers side is cracked.
- One of the sunroof gears is stripped.
Can also include the following:
Robby K / Iceshark battery + headlight harness cables ($275)
Turbonetics Delta Gate Mk2 ($100)
Original K26/6 ($100)
968 M030 Rear Rotors ($250)
87+ Front control arms for rebuild ($50)
Porsche 968 Black 10-speaker door panels - ($350)
Original late 944 black door panels - ($250)
TechArt 15mm Spacers - TUV Approved ($100)
New Rear Hatch seal ($80)
Records:
96k miles:
- Lindsey Racing Dual Port wastegate, with all new gaskets
- Stealth MAF kit, 3" silicon J boot to factory airbox.
- New Bosch OE Oxygen sensor
- New heater control face plate
95k miles:
- Amsoil gear oil in transaxle
- Re-seal throttle body
93.8k miles:
- Oil change - OE filter and AMSOIL Dominator 15W-50W (never under 2.5 bar at hot idle)
- Becker CR220 + iPhone cable
- New suede shift boot + Stainless shift pattern
89k miles
- 930 clutch disk with Sachs Sport pressure plate
- throwout bearing, guide tube, release fork bearings, rear seal
- clutch master, slave, and hoses
- oil change - OE filter and Valvoline Synthetic w/ turbo bearing additive
87k miles
- Vitesse Racing stage 3R kit. Oil cooled turbo, water cooling delete.
- Vitesse VRT8x piggy back
- V-Flex upgrade
- Zeitronix Zt-2 Model 2010 with LCD display
- All radiator hoses replaced with LR silicone
- Heater valve
- Coolant overflow tank
- All vacuum lines replaced with LR black silicone lines
- Fuel damper
- New fuel line from damper to rail
- OEM 3bar FPR
- Power steering line
- Fuel rail, coolant lines, heat shield, brackets etc. all re-plated in cadmium
- AOS seals
- LR stainless braided turbo oil feed line
- LR silicone intercooler/hard pipe hoses
- LR silicone venturi delete kit
- Deleted hard lines and CV, boost is controlled by Vitesse PB/solenoid/factory DME
- radiator cap
- oil cap
- TPS
80K miles
- OE 964 Turbo "Big Red" brake kit, 965 rotors front
- OE timing and balance belts
- OE waterpump and thermostat
- OE 968 motor mounts
- motor resealed
- all coolant hoses replaced
- OE Porsche (Behr) radiator
- Bosch starter (not a rebuilt one)
- OE 993 blow off valve
- Weltmeister lowering springs
- 4 wheel street alignment
- OE Porsche pads
- Lindsey braided fuel line kit
- all ps hoses
- all belts
- ps reservoir
- ps pump resealed
- Interstate battery
- fan controller
- plugs, Mobil 1 oil and filter
- AC just serviced with R12
- Clubsport center tray
- header panel emblem
79k
- OE 968 aero mirrors
- OE 968 door handles
75k
- Alternator and plug wires
- Bosch HV Turbo fuel pump and filter
- Lindsey 3" exhaust w/ hi-flo cat, smog cat, and test pipe
70k
- Koni adjustable Shocks and Struts (not MO30)
Options:
220 LSD
341 Central Locking
418 Side Moldings
454 Cruise Control
946 Leather Seats
Drivetrain:
- LR silicone hoses
- 993 BOV
Exterior:
- 968 Mirrors
- 968 Door Handles
Interior:
The not so good:
Records:
96k miles:
95k miles:
93.8k miles:
89k miles
87k miles
- V-Flex upgrade
- Heater valve
- Fuel damper
- OEM 3bar FPR
- AOS seals
- radiator cap
- oil cap
- TPS
80K miles
- motor resealed
- OE Porsche pads
- all ps hoses
- all belts
- ps reservoir
- ps pump resealed
- fan controller
79k
75k
70k
Basic Sponsor
Lartmobile # 158, oh yeah
http://stores.ebay.com/Larts-Porsche...0&_sc=1http://
https://www.ebay.com/str/lartsporscheparts
