It sounds logical to me that if the shaft broke the impeller would pull itself forwards like a propeller.
The turbine impeller is spinning in opposite direction, so theoretically it would push itself in. In practice however since it is spinning very fast, it disintegrates when its balance is lost. Thats where burst containment comes in.
Turbine is the hot side of turbo and when shaft is broken that usually means impeller broke off the shaft on the hot side. Besides, compressor impeller is bigger than the intake hole so it can not get out without exploding to peaces.
Uh oh, I found the speedforceracing website. I'm a sucker for bolt-on things. They have a GT35R bolt on. Plus I've still got stock exhaust headers and they have all sorts of the piping I've been wanting to replace. Might even have to pick up their intake and throttle body if it will work well with the 2.7L head.
Spending a whoole lot of money on a new turbo though is scary when I have little pieces of the last one all over and inside everything.
I would really like to see if my engine still runs. Is there any easy way at all to run the engine without having a turbo installed? It seems like an impossibility. I guess leak down test is all I can do.
Also wondering if I should trash the intercooler. Dunno if I trust it.
You might want to call them (SFR) first.
Take your intake off and check to see if you can find any metal bits. Also clean the hell out of your intercooler while checking for pieces. Have you started looking?
Here's a picture of the torn air filter. I guess this is a good PSA to check your air filters regularly. Are K&N filters just crappy? It failed in such a way that the hole would expand under full throttle I bet.
I haven't taken the intake off yet or the intercooler. It's too hot right now and I need to get the evo over to get inspected today, and I have Palmer event next weekend so I'm not sure when I can get to it. Oh and it's still on the trailer and I have to figure out getting it off so I can work on it
I have a pressure washer, I could probably blast the intercooler that way, but i'm still worried all the little stuff won't come out.
Also, you can see in one of the pictures, but there's a fine 'powder' of turbo all over the insides of everything. I don't know if this would have burned off in the head or not.
I'm still debating if the head itself needs to come off. I guess I'll start with leak down.
The engine runs very well still. I jammed the MAF pipe on to the throttle body and plugged some of the vacuum leaks and yeah, she's running good still. I didn't want to run it too much as I had not removed and cleaned the intake, but I just wanted to see if it was worth doing anything at all with. I tried to do a compression test but the engine wasn't fully warm and I forgot to hold the throttle open but I got 142, 110, 133, and 124. I'm trying to remember what they used to be but this sounds about what it was like a couple years ago. Tired but runs fine enough until the 3.0L is done.
Okay, after speaking to the super nice Tim at SpeedForceRacing, I'm going with the GTX3582R with the Tial 63AR v-band housing and their billet turbo-engine mount. I'm upgrading the rest of the kit too for some reason, so their intake with 70mm throttlebody, 2.5" intercooler pipers, Tial BOV, their stage 2 intercooler, 321ss stage 2 headers cross over pipe and the 3" downpipe, a 46mm tial waste gate and a new manual boost controller.
When I finally get the 3.0L built, I can get the intake port matched and get the .82 turbine housing. But all my 'build the engine' money just went in to the 'replace the turbo/intercooler' project. Bah.
Oh yeah? I still don't know what the real failure was. There was a nut still attached to the compressor wheel. But the shaft snapped in the middle for some reason or another. I'm dying to get a closer look at the turbo but that won't be til the end of June. It's amazing that I can't even find a day right now to work on the car :P
Mine is similar. Let go last year on 17lb. boost shifting 3rd to 4th. Like yours, found the impeller and other pieces in the MAF filter, but the filter was not torn. Amazingly the MAF sensors appear in tact, but won't know for sure until it's put back together.
Definitely not reusing the IC. Bought a used one from Josh B. Regardless of any kind of cleaning, even by a professional, I would not trust it. Something could stay lodged in there and break loose one day.
I was able to shake out of the IC a small hand full of various size fragments, but not nearly all of the compressor wheel. There were only two large pieces of the back plate found. Hmmm, where did it all go?
Exhaust side appears to not have made contact, but excessive axial play makes it un-rebuildable.
Because you are sure the used one hasnt suffered a similar fate?
No way to absolutely know, but I bought it from a good seller who thinks it is okay. It was relatively clean and nothing whatsoever came out of it. I used a product called Oil Eater and soaked/washed it out four times. Nothing came out except for the remnants of Royal Purple oil. I think it's a good.
Wow, sorry to see that but sort of glad I'm not the only one. Yeah, I thought about cleaning the intercooler but the new turbo cost a serious chunk of change and I am just not risking it happening again.
If anyone wants a tainted Lindsey Racing Stage II intercooler cheap let me know Maybe if you have an ancient crummy turbo you aren't concerned about lol.
Yeah, despite the tear which may have been caused by the impeller itself, the turbo could have just exploded on it's own. I've been wondering what might be the cause. Heat stress, poor oiling?
I remember my mechanic telling me that the last mechanic who did my timing did not drill the hole in the water pump for the turbo hose so it never had any cooling. That had been fixed but maybe that had weakened the shaft? I usually let the car idle a bit after a run though so the oil should help but who knows.
