Garage sale
Stock intercooler, good condition and no dings-- 80
Two good, clean 3 piece OPRV -- 60 each
Working hatch unlock motor-- 20
Tested working early 90 amp alternator--50
working rear wiper motor-- 50
N/A AOS/oil filler unit, good condition -- 20
Stock intercooler hard pipes, small dings w/couplers -- 30
factory Silver 951 rear valance--- 150
944 turbo coolant expansion tank-- 60
2 good used factory fuel pressure dampers -- 10 each
set of late offset power inner tie rods, never installed and still in plastic --50
set of late offset power inner tie rods, installed and used for about 1 week on the street before I converted to early offset --40
working headlight motor--30
Complete pair of rear seat belts w/ receivers-- 75
Cam tower with cam, no lifters-- 50
4 late car cooling fan relays (one 944.615.104.01, two 944.615.104.02, one 944.615.104.03) 40 ea
Brand new front cam cover with new gasket, never installed--30
4 fuse tester relays---5 each
two Crank/alternator pulleys --10 each
crank gear-- 10
two balance shaft gears #944 102 205 04--- 10 each
timing gear #944 105 125 02----10
2x power steering cooler-- 15 ea
Wastegate shim--10
pair of NA motor uprights --- 20
A/C/alternator belt tensioner rod-- 10
944 schnell Short shifter kit (the transmission linkage)--- 50
set of 4 cast N/A rods and pistons-- 80
944 turbo DME altimeter #944 606 151 00-- 15
alternator/AC mounting bracket-- 15
pair of late tan leather seats, ripped, driver side is power-- 125
fuel vapor control valve and electrical test/diagnostic outlet--- 20
late offset conversion stuff, caster blocks, sway bar drop links, ect -- ask about them
crank gear-- 10
Wastegate shim--10
