installed M-tune..running pig rich
#31
Knowing nothing about the tune other than the brand name (it was in there when I purchased the car, and it's old) I decided to move on to the M-Tune for safety and piece of mind when I installed the Super 48.
I'm confident I'll get this sorted with Joshua and Dave's help. Joshua and Dave gave me some things to check this weekend, I'll report back.
Can a collapsed exhaust make the car run rich? I bought a bore scope (USB endoscope) and will fish it up the exhaust this weekend to check that too.
#32
My car was running ok. I want to say the car was running rich prior to the install but the WB02 sensor was located near the wastegate which could have been giving a false reading. I moved it to the proper location prior to going in the shop and it was reading rich. There was a few things that needed to be done. But there was a difference in dyno results before and after the install. I lost some hp. I am going to wait to see what the shop comes up with after they talked with Josh. I will let you guys know what they find.
#35
I have an LC-1 also. I have not driven my car much since M-tune but I am wondering if it may be the LC-1.
I will be driving mine this weekend and will also recalibrate it. My AFR's are a little off. It does respond to the frequency switch changes and I also need to double check my fuel pressure.
There was a recent post about LC-1 issues.
I will be trying a different brand o2 sensor since I'm building 2 more project 951's
#36
Quit Smokin'
My first go around I had the second version of the Innovate wide band tuning tool. It was TERRIBLE. Constantly locking up (though admittedly more trouble when running an RPM trace to it). One of my local friends has good luck with an autometer WB, and i bought a PLX devices WB for my chump car. I've had enough good luck with it that I bought a second for my 944. I believe Zietronics used to be the big name in german car world. Never had one so I can't comment. All I can say is that I had enough trouble with my innovate product and their customer service that I will never buy another product from them.
#37
I am using a AEM Wideband. Below is link to their website for the one I am using. I had to replace mine because it stop working. That's when I noticed it was in the wrong location from the previous owner put it. Based on instructions, the previous location could have shorten its life span. I noticed that it was much more accurate and stable in the correct location vs the old location.
At idle and normal driving my car hovers around 14.7. Which is ok but who wants to drive normal with our cars. Only at full boost does my A/F ratio drops close to 10.
http://www.aemelectronics.com/?q=pro...uego-afr-gauge
#38
#39
I never read anywhere that a collapsed pipe can make your car run rich. I might have my car scoped as well. Please someone correct me if I am wrong, but from reading these forums, if the collapsed is in the crossover you may make little to no boost. If the collapsed pipe is in the downpipe to cat then you may make boost the but engine and turbo will definitely have to work a lot harder to overcome the restriction. Engine may feel bogged down or held back so to speak. If mine happens to be collapsed, I will let you know which one and difference in the car.
#42
#44
I see from the picture this look like the section of the exhaust that goes to the cat. I know some call section from turbo exhaust to the cat, the downpipe. But was your small section of piping coming off the turbo that bolts to the exhaust going to the cat collapsed as well?
#45
I have that section of exhaust removed from my 89 951 at 69K miles if you need it. Send me a PM if you are interested.
