Apexi AVCR setup questions
Originally posted by Theo951
The AVC-R does not provide gear based boost as unit is often promoted.
Originally posted by OZ951
You mean like this ?
Now.... how about the wiring diagrams that the device connects to..... (blue wire to dme pin number X) ... etc
oh and all the setting values of the AVC-r that correspond to our cars....
In one nicely laid out sheet.
Originally posted by rage2
Yes it does. It's a bit "ghetto", you can +/- duty % in each gear. I use it to combat wheelspin in the lower gears.
Rage2 :
Thats the main reason I bought an AVC..... so how well is it able to perform this function.........? What psi do you have the car set up for in each gear?
Originally posted by AlexE
Rage2 :
Rage2 :
103 octane "B" map, 17psi 1st gear, 22psi 2nd gear, 28psi 3rd-5th.
It does the job very well. You can see it in action in my incar drag video.
http://www.virgeweb.com/rage2/944t/2...1-12.7@117.wmv
Right click and save before viewing.
Pump fuel "A" map, 12psi in all gears (that's all 92 octane can do).
Sorry to hijack the thread........ but Holy crap 28 psi...
Rage......
So the AVC will respond that quickly (every shift change).... Very slick
I am running 91 octane up here in Edmonton (all I can get). I am starting to tune my car to run 15psi with vitesses piggyback and I am going through my AF's and changing the AF ratios to 12:1 at WOT just to be on the safe side......... but I am getting some serious wheel spin in 1st and was hoping to combat this by running lower psi as well. Do you think I am stretching it running 15 psi on 91 octane? I thought I was still on the safe side with the proper AF ratios?
It's all about the turbo. I've got a big turbo that crams more air into the engine at 12psi than yours at 15psi. On 92 octane, I max out at around 280whp on a Mustang dyno (that's about 330whp or so on a dynojet).
http://www.vitesseracing.com/Catalog.../stage_ii.html
.... on a side note I removed the CAT today and replaced my exhaust with a custom 3" full exhaust........ YUMMY..... What a difference....... It is spooling so much faster. It feels like its GULPING air now......
by the way I may see you at SCC on the 21st..... good luck with your efforts!
Very nice OZ.... u the man.
Great info, thanks to all (Matt, got your forwarded .doc, thanks!)
It's too bad the speed sensor pulses won't work directly.
For EBC, if I want to map boost to rpm, are there any better choices than an AVC-R?
Sam
Sam
Sam no problem but credit belongs to Dave McGrath, he sold it to me and sent the instructions along.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
OK I summarised the setup information into a pic which you can see here:
I dont have the manuals in front of me but if someone can let me know the wire colour for DME pin 1 and KLR pin 22 (RPM+TPS) I will add that info to the pic.
You are my new hero OZ. Is there anything we can do for you.
