Finally back to a real 60-2 Trigger Setup
Old 04-29-2015, 12:03 PM
reno808
reno808's Avatar
Default Finally back to a real 60-2 Trigger Setup
Clewett Engineering..... I had the Chris White to get me out of the hole for a bit and it only made it WAY worse....
Old 04-29-2015, 12:08 PM
spives
spives's Avatar
Looks top notch! What issues were you having with the previous setup?
Old 04-29-2015, 12:14 PM
reno808
reno808's Avatar
chris white setup. the 60-2 tooth wheel is not even true. and what ever you do DO NOT adj the alt belt.
Old 04-29-2015, 12:18 PM
reno808
reno808's Avatar
I kept getting trig errors.
Old 04-29-2015, 02:32 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Did you get trigger errors with the stock speed/ref sensors too?
Old 04-29-2015, 02:57 PM
reno808
reno808's Avatar
I started to get triggers errors with the stock speed/ref sensors as i was pushing the car on the dyno. I was spending more time adj the filters for the speed/ref senors. This is the reason why i went with the 60-2 setup. With the CW setup i started to have issues at high RPM because the wheel wobbled due the the wheel not being true. then i was having even more issues when i had to leave the car outside and the wheel started to develop rust.
Old 04-29-2015, 03:09 PM
alxdgr8
alxdgr8's Avatar
Sounds like the problems I've had with 60-2 crank mounted triggers on my Audi. I even had the wheel trued to a crazy degree and still had problems. Moving to a flywheel 60-2 trigger.
Did you ever scope out the actual sensor to see the waveform stability? And measure peak-peak voltages?
Old 04-29-2015, 03:58 PM
reno808
reno808's Avatar
The flywheel 60-2 would be great, but i missed out on that option due to low car funds.
Yes as matter of fact we test 3 sensors all very close to specs.
Old 04-29-2015, 07:13 PM
alxdgr8
alxdgr8's Avatar
Hope the Clewett piece works!
Even after true'ing on a lathe, this was the best waveform I could get with a crank trigger wheel. There's still vibration of the crank and mounting points that'll cause variation.
Looking at the CW setup, it's not surprising it didn't work well. That's not a very secure place to put it.
Gap is also critical. Most like gap of 0.025" or less. Also some sensors don't have a perfect symmetrical polar pickup pattern, so sometimes it helps to try rotating the sensor (all while maintaining the correct gap).
Old 04-29-2015, 07:48 PM
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Albert is using that setup on his builds, he says it is very reliable.
Old 04-29-2015, 08:36 PM
rlm328
rlm328's Avatar
Whose ECU are you using? I am using the cam gear for my ref and sync.
Old 04-30-2015, 01:00 AM
theedge
theedge's Avatar
Thats a Link G4
Old 04-30-2015, 01:12 AM
azbanks
Freedom Enthusiast
azbanks's Avatar
Could you run an S2 or 968 Flywheel?
Old 04-30-2015, 02:58 AM
333pg333
333pg333's Avatar
Patrick Motorsports makes a 60-2 fly. I think Rich Luciano bought one from memory. Looks like reasonable costs vs alternatives. http://www.patrickmotorsports.com/
Old 04-30-2015, 03:46 AM
KSira
KSira's Avatar
What ecu and trigger sensor are you using? I had no trouble with the Chris white 60-2 set up.
Quick Reply: Finally back to a real 60-2 Trigger Setup
