Dyno'd the 951... any guesses?
I've had a lot of cars, some a lot faster than this one, and I've kinda fallen into the perfect comfort zone with the 951. Just enough power to stretch a smile on my face and be wicked fun without being ridiculous... and it stops/turns better than it goes (which is a balance I prefer).
I usually aim for 11.9-12.0. Leaves a little on the table but you're not flooding the cylinders either. Once you get up into the 12.5 range you're not leaving yourself any margin and should keep a REALLY close eye on knock. That's the way I've always tuned anyways... *shrug*
I did notice, when comparing logs over the 3 pulls... as IAT's went up, AFR's got quite a bit richer. I might play around with the IAT compensation tables a bit... might help alleviate some performance drop-off on really hot days.
And boost tapers but only slightly... from 14.6 through 5200, 14.4 to 5700 or so, down to 14.0 by the rev limiter.
