M-Tune injectors ?
M-Tune injectors ?
I'm sure Joshua gets lots of email queries so perhaps mine got overlooked, so anyway 80# or 160# injectors ? I see the info on Lindsey's site re power output/E85 but if the software can run the 160# as efficiently as the 80# at lower revs is there any reason to choose the 80# ?
So from what I was told by my tuner is that you don't want to run your injectors anywhere near 100%, but maybe that's because of the fact that I'm getting a full infinity stand alone system
I also have this same question. Just ordered the M-Tune from lindsey racing for my 3.0 968 turbo and was wondering about the #160 injectors and if it was going to make for idle issues. Any input on this would be awesome. Thanks.
As I'm sure you're aware, when catering for E85 and injectors you have to allow for at least an extra 30% of fuel usage. So if you're not going to run E85 then you can dial back your inj size somewhat. Clearly you need a decent software system that will let you tune / idle with large injs.
I understood that one of chief advantages of sequential injection, apart from some minor emissions & economy improvements, was the abilty to have a stable idle with big injectors.
If your standalone set-up includes a cam trigger then sequential may be an option.
Tim
Tim
At the moment E85 isn't an option. I just want to know if the 160 injectors run as efficiently at low speed as the smaller injectors, if so why not just supply the 160's ?
