Some 3.0L turbo build questions
#61
Use 951 timing belt. And 951 aluminum auto ajuster if you can get one. And a Kevlar timing belt at that. Use all 951 stuff. S2 never had an 8v head. That is unless your using a 16v head in which case use the S2 timing setup.
#63
Would you sell crank side 16V timing belt pulley? I need one..
Balancers crank pulley is probably the same 8/16V?
