ABS problem
-91 951. Abs not working. No anti-lock warning light. Not even the first few seconds when ignition is on. Not a sound from the pump either.
Actually NO warning lights except the big ! seem to light up when I turn the ignition.
Would appreciate an abs wiring diagram and an abs ecu pin assignation. The few I've found on the net are very bad resolution so I cant make out what is what.
Fredrik
Fredrik
I always think its annoying with all these troubleshooting threads where the solution is never presented.. so... Completing this one with the solution..
As you can see from the wiring diagram there is a connector in the passenger compartment, somehow when installing the EMS or wiring some other stuff this had been unplugged.. So, easy fix really
